Sing along care bear isn't singing.
Can I fix the speaker issue myself?
Update (01/13/2017)
I have a talking care bear from 2004. It wont work. There is no corrosion in battery compartment. I put new brand name batteries in it. It makes a beep noise when i switch it to the on position, which it always did when it worked for my eldest daughter. But when we press the talk button nothing happens. I've tried other new batteries and everything. My toddler loves care bears and i hope someone finds a solution to fixing these. Any help is appreciated
2条评论
Have you tried replacing the batteries first?
由 S W 完成的
Hi @sparklefaceprincess,
It may be able be fixed but you would have to know how to diagnose faults in an electronic circuit.
Any reputable, professional electronics repairer would probably be able to find out what the problem is. The difficulty then may be getting any proprietary replacement parts if they are required. They may or may not be available any longer. This is conjecture on my part but perhaps something to be aware of. It may not come to this though. It might be something obvious to the trained eye and easily fixed.
由 jayeff 完成的
