跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Have no sound but speaker works!
Hi.
I have some problems with my iPhone. I have no sounds like lock/unlock screen, have no sound when somebody is calling, no keyboard sound, but when i went to settings and choose the ringtone there is a sound!
Do you have any suggestions how to fix it?
I'll be very pleasant for any help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
have you tried to reset to original- go to settings, general and then choose reset settings. yes you may lose contacts etc so do a back up first
the next thing to think about is what happened about the time you noticed speakers not working? a fall? downloaded an app? is the phone jailbroken? etc
这个答案有帮助吗?
得分 1
添加一条评论
You'll need to recover your device using iTunes first, then we'll maybe be able to point out hardware problems. This is likely to be a software problem.
这个答案有帮助吗?
得分 0
添加一条评论
There is a New Dock with speakers installed and New flex tape.. I have updated software to 3.1.3 but the problem still exist, any ideas how to fix it? Maybe it's a problem of logic board?
这个答案有帮助吗?
得分 0
1条评论:
it doesn't sound like a speaker problem-more like settings/software. afterall your sound is working!
完成的
添加一条评论
I'm almost sure it is your dock. It's broken so it makes the iphone think it is connectes to some extern speakers so that the internal speakers are off.. Consider replacing the dock connector.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mateusz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 9,445
