跳转到主内容
Vertical line problem on retina screen
I have been using MacBook Pro A1502, late 2013, 13" retina display over a year and i don't have the international warranty anymore. Now, i took it out to work the other day and when i came back home i saw a vertical line. I pressed the bottom area of the screen left-to-right hard where basically the cables or connectors should be, and the line disappeared. It's not exactly on the screen, it's on the black plastic below the screen that connects MacBook body and the display (see the image i have marked the area).
It was months ago, but now the line is back again. And, this time there are two lines. So, i pressed that bottom area again since it worked last time, but nothing happened this time, and 3/4 lines appeared instead. I pressed few more times, 2 lines are gone but there are two overlapping lines not going anywhere. I have attached images of the problem, also i marked the area where i do the pressing.
What do i do now, please help me out.
Sincerely Yours
Mahmud
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
12条评论
That looks like a TAB error. Apply some downward pressure on where the line is and see if that changes it. If so, it is a TAB error. There is no way of fixing it.
完成的
I have pressed downward, nothing seems to work now. what's causing it anyway?
what is a tab error anyway? Googled over it, didn't find anything like this. I am not expert but since the touching changes the lines, doesn't that mean that there's some cable/connection problem somewhere ??
完成的
TAB's (tape automated bonding) A TAB fault is caused by a connection failure from the TAB that connects the transparent electrode layers to the video driver board of an LCD. So in theory you are right that it is a cable/connection problem just on a level that it cannot be repaired by conventional means.
完成的
@oldturkey03 ah that's what it was called, was trying to think of the name when writing the answer. Used to have one of these where I used to work, which used split imaging to line up the ribbon and heat the tape. Cost an arm and a leg, so definitely not worth buying to fix a Retina screen ;)
完成的
we have the same problem :(
完成的
显示更多的7条评论
添加一条评论
1个答案
已选择的解决方案
Either the polariser of screen is fractured (behind the black border at the bottom, so this won't be visible unless the screen is removed), or the ribbon where the screen PCB is soldered to the screen has slightly come away, so when moved the lines cut in and out.
Whichever issue it is, the only solution would be to replace the screen. The polariser is part of the screen, and the PCB is not soldered to the screen using standard methods (soldered the same way an LCD cable is soldered to an iPhone screen), so you would need a special machine to do this.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Md. Mahmudul Hasan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 95
总计 156,354
