跳转到主内容
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
Is it possible to apply Thermal Paste?
I saw some thermal pads on the N8's mid-plane. Now my phone will auto-restart and continue restart when the phone is in warm environment but it will be all right if getting it directly under an aircond. So, I was thinking will apply thermal paste helps this. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Sounds like that'd work, there's a similar issue with older HP laptops which only have thermal pads and then overheat and continually restart- the solution is to apply thermal paste. The thermal pads alone aren't good enough for keeping it cool, so thermal paste will help you out there. You can get some thermal paste here, and here's a guide for installing it.
这个答案有帮助吗?
得分 1
3条评论:
Hi, thanks for your reply. I had a thermal paste which I used for my PC. I will go to Nokia Care first before I done anything on it (it's still under warranty). If they failed to fix it, then I will try to find those screw drivers to open up my Nokia N8 and apply them.
完成的
You may want to read this article
http://www.engadget.com/2010/11/18/nokia...
完成的
I read that already. Thanks. I had sent for warranty and have to wait around 1 to 3 weeks for the motherboard to arrive.
完成的
添加一条评论
添加你的答案
Peng Fong Er 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 2,751
