跳转到主内容
加入维修社区 - 创建账户
一款以拍照功能著称的 Windows 手机。也称为 Nokia EOS、Nokia 909、Nokia RM-875、Nokia RM-877、Nokia RM-876。
Can I repair the rear camera without replacing it?
the rear camera did not work before and I replace it but within less than three months the new one is not working. the problem is that the focus is not working so the picture is blurred and if I try to take a picture of a note or a page of a book, the only thing I can see is the lines without being able to recognise even a letter.
Is there something that I can do?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@nusha , nuha, you could disassemble and check and clean the connections, also make sure the camera is locked into the correct position and see if that helps, if not you may have to replace the camera.
Below are a couple links to your device, they will show how you can get inside phone to access camera. 1st link is tear down of device, 2nd link is service manual. Also I posted links to a couple forums that trouble shoot your issue, If you google your Nokia Lumia 1020 camera not focusing problem, you will see there is a lot of info. out there. Good luck.
Nokia Lumia 1020
http://devdb.ru/data/file/file5245f74f49...
https://forum.xda-developers.com/lumia-1...
http://forums.windowscentral.com/nokia-l...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nuha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 638
