跳转到主内容
加入维修社区 - 创建账户
Battery won't charge - problem with MagSafe board?
A friend spilled coffee on my laptop. luckily, it wasn't an awful lot. after a good cleanse everything else seems to work wonders, except the battery won't charge.
is there a good chance the MagSafe board got fried from the spill?
alas, it's not the adapter or outlet, as both are working fine to charge another MacBook.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
If the unit runs off the magsafe, then it's probably not the DC-IN. It's probably the battery connector. Does it boot and run OK? Download and run Coconut Battery to find its status and let us know: http://www.coconut-flavour.com/coconutba...
这个答案有帮助吗?
得分 1
3条评论:
good answer +
完成的
the machine would boot and run fine. it was running normally for a few hours before I had to plug it in and realized it wouldn't charge the battery.
I brought it in to be serviced and they ran some diagnostic off a USB key that reported all was well. despite the battery not charging.
thus, I don't have the laptop in my possession now, but what you're suggesting is that the battery needs replacing?
anything that doesn't mean my logic board is fried is good news
完成的
annnd their verdict is the logic board needs replacing
完成的
添加一条评论
添加你的答案
wyattmike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,997
