跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
1 Beep every 5 seconds!
I change the memory, the power supply, the Logic Board and the Processor and change the hard drive just in case, but still one beep every 5 seconds!!!! What can I do? The iMac does not boot, just turn on the fan... I tried SMC reset and other keyboard fixes but the keyboard looks like does not have power. :-(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Any updates friend? My mac is beeping one time also and now i'm afraid to repair it if is possible that the error persists
完成的
添加一条评论
2个答案
最有帮助的答案
On the Apple site it tells that there's no RAM or it's not supported. It only supports 600 MHz PC3-12800 DDR3 SDRAM SO-DIMMs (204-pin). The RAM might also not be properly seated or the sockets are broken or the slot pattern isn't like it should be (the way the RAM is in the 4 sockets might not be in the right order) or one or more dimms are defective.
这个答案有帮助吗?
得分 1
2条评论:
I receive all that information and change all the memories. Also, I change the logic board and processor and the problem persist. A local Apple technician try to fix it too, but fail. Right now I have a new iMac. The one with the problem is in my office waiting for repair. :-( If there is a possibility that the problem is about software?
完成的
Have you tested above things already?
完成的
添加一条评论
Try disconnecting the Headphone Jack on the mainboard
这个答案有帮助吗?
得分 1
10条评论:
OMG, #jontaine , u r a saver, disconnect the headphone jack really work for me , Thanks so much !!
完成的
One of my client's iMacs had the exact same issue. After pulling my hair out having swapped out RAM, cleaning the connectors with IPA, changing the order of fitting RAM etc, I came across this article. This morning I disconnected the headphone jack from the logic board and BAM! It now works! How incredibly random is that?? Good old Apple.....
完成的
I tried disconnecting headphone jack connector but no luck
完成的
@indra - Sorry that’s a Red Herring!
This only works is the headphone jack has the DAC chip on the daughter board with the jack socket. Not all systems have this setup. And this only happens when the chip has shorted out.
完成的
@danj my iMac is 27 inch 2015
完成的
显示更多的5条评论
添加一条评论
添加你的答案
noelfoto 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 4,374
