跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Toshiba TV.
TV remote control won't change volume even with new batteries
The remote control works for everything on the TV but hardly works at all to change the volume level. I have to keep pressing the button over and over to change the audio level but most times it will not work at all. I have put in new batteries but that does not change anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
8条评论
Hence tv volume wont go up or down .but trun it on and off.
完成的
The volume ethier is not working
完成的
Nothing works on it
完成的
I will not work on volume
完成的
I can't change sound tv but works on everything else
完成的
显示更多的3条评论
添加一条评论
10个答案
最有帮助的答案
@chemainiac , Ian, find below a few links on how to dissmantle and clean a remote when 1 or more buttons are not functioning properly, may not be your exact model but fairly generic to clean remote. If after cleaning your remote still not functioning properly, consider replacing it with a univerasal remote which sometimes can even be found at the dollar stores or any big box store selling TV's.
https://www.youtube.com/watch?v=yWpMcXWl...
https://www.youtube.com/watch?v=gVr8eLW0...
https://www.youtube.com/watch?v=xvJWqf_b...
这个答案有帮助吗?
得分 4
1条评论:
As a qualified electornic technician that spent his whole apprenticeship fixing remote controls this is the best method. Another thign you can look for is fractures in the PCB around where the volume control buttons would sit. you might of cracked the PCB by pressing the buttons harder when they get less responive.
ANother thing to note is like model remote controls tendto work on the same devices. I have the same samsung remote for my TV that i grabbed out of a media installtion i did else where. the remote does all the basic functions fine, (power, channel, menus and volume) so picking up a second hand remote of the toshiba brand is also an option.
完成的
添加一条评论
这个答案有帮助吗?
得分 2
2条评论:
Victoria, have you tried the fixes described by L Pfaff and Shabeena Shaik? If not, please do so and let us know what the results were.
完成的
When I hit the set button it shows that the TV is on set I want to hit the volume button it shows that that's on TV
完成的
添加一条评论
how to fix when Device Won't Respond to Remote Control Commands
Make sure your components are turned on and yourTV is set to display the appropriate video source.
You must put the remote in the correct mode bypressing the corresponding component key (TV,DVD, VCR, AUX, SAT·CBL) so the remote knowswhich component you want to operate.
Remove any obstacles between the remote and thecomponent. Make sure to aim the remote at the IRsensor on the component.
Make sure the batteries are fresh and are properlyinstalled. Replace the batteries with two new AAAbatteries, if necessary. Reprogramming may berequired.
Reset the remote using these steps. If the indicatorlight lights up, reprogram the remote and try again.If it doesn’t light up, replace the batteries with newones
这个答案有帮助吗?
得分 1
1条评论:
Maybe it's only the batteries?
完成的
添加一条评论
Dude it's the batteries most likely, replace with unopened pair of identical batteries and refresh, if you still have issued .. call geek squad.
这个答案有帮助吗?
得分 1
2条评论:
New batteries.the remote gave out already
完成的
New batteries don't help
完成的
添加一条评论
Why is my remote not working on volume control
这个答案有帮助吗?
得分 1
添加一条评论
This could be due to that particular button not making electrical contact with the printed circuit board's contact pad. Especially a button constantly used such as the volume button.
I have fixed many remotes, cordless phones and the like with similar problems where a few button functions don't work. And the fix I use is to (like previously suggested) open and clean both the printed circuit board and the rubber keypad. (I just use methelated spirits). Then I dab the problem button, as well as any other suspicious looking ones, with what is called Conductive Paint which can be purchased online. I use a toothpick to apply the paint - it comes in a very small bottle and just a tiny amount is used per button.
The reason is that these rubber keypads are coated with a conductive layer (usually black) that rubs off with frequent use.
The solution above is thus just to re-coat the button with a conductive material.
Please note that depending on the keypad, your conductive paint may need to be replaced every now and then depending on use and paint adherence.
To lengthen the result, keep the following in mind : DO NOT APPLY UNDUE PRESSURE ON THE REMOTE'S BUTTONS. ONLY A VERY VERY SLIGHT TOUCH IS NEEDED.
这个答案有帮助吗?
得分 1
1条评论:
See also my other suggestion that reccommends purchasing stick-on conductive pads specifically for remotes. They come in various sizes, are cheap and available online or from electronic component shops. NB. Clean both the circuit board and rubber keypad thoroughly with meths or rubbing alcohol before applying the stick-on pads.
完成的
添加一条评论
Av button is repaired
这个答案有帮助吗?
得分 1
添加一条评论
well with my remote (HDMI) I don't know what it is called after HDMI but with mine, it is like it is not working I think you should contact the company or get another company or something
这个答案有帮助吗?
得分 0
添加一条评论
Good remote and is working very fine
这个答案有帮助吗?
得分 0
添加一条评论
All the buttons work on my Axess remote, but the volume does not work
这个答案有帮助吗?
得分 0
1条评论:
Please. Help.
完成的
添加一条评论
添加你的答案
Ian 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 102
过去 30 天: 554
总计 73,737
