跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
380 个问题 查看全部
N3DSXL only turns on with blue light then shuts off.
Hey all. I am repairing a N3DSXL and replaced the bottom screen with a replacement from ebay. Unfortunately, the 3DS won't turn on when I try to boot it up. It turns on with the blue power light and the bottom screen can't really turn on and a slight 'pop' is heard.
Here is the screen I replaced it with:
http://m.ebay.com/itm/Replacement-Lower-...
I did take it apart several times more to check for loose ribbon cables but, no dice. Any ideas what it might be? The screen seems to differ also in that it has one less gray-ish connector on the top. But, that's just what the replacements seem to look like. Everything is connected properly and I didn't forget to connect anything. Could I have connected one of the ribbon cables found underneath the motherboard incorrectly?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
Hi Janis,
I've answered a very similar problem with a 3DS XL that would shutdown as the user closed the lid. This is the same exact problem as you've indicated here with the "popping" sound. There is a fault in one (or all) of the ribbons in the hinge of the device.
See my 2nd answer here: 3DS XL shuts off sometimes when closing screen, to solve this problem and get your device running again.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Janis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 8,488
