跳转到主内容
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
388 个问题 查看全部
3DS XL shuts off sometimes when closing screen
I have a 3DS XL that's in fairly good condition that I'd like to be able to reuse or resell.
Problem is, after a long period of disuse, when I finally charged the battery, I began noticing problems.
1) The charging light will turn off after a period of charging, I'm pretty sure it's supposed to stay on as long as it's plugged in, at least that's how the New 3DS XL works.
2) More importantly, sometimes, upon closing it, instead of going into sleep mode it will just shut off completely, and needs to be turned on with the power button. I haven't been able to replicate exactly how it's happening.
Does anyone know what could potentially be causing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Sounds like you have the following problems.
  1. This seems to be a battery going bad and not able to hold a charge anymore. Try getting another battery or a cheap one off eBay to see if that fixes the problem.
  2. There is a nick or fault in one of the flex ribbons going from the top portion to the lower portion of the XL. You're going to need to tear the system down and inspect all three ribbons to see which one is faulty or near busted (it could be all three as well). Generally, there will probably be a tiny cut or severe crimp in the ribbon that is causing the system to short out and shut down.
Follow this guide in order to get at the three ribbons: 任天堂3DS XL LCD显示屏更换
Good luck with the inspection and take your time.
这个答案有帮助吗?
得分 2
4条评论:
The battery seems fine - if I don't close it, it'll happily run for hours and hours until it runs flat - but the ribbon cables do seem likely. I'll take it apart and check once my new #000 screwdriver arrives - old one's gone walkabout somewhere.
完成的
@starayo Oh, don't know why I didn't think of this. You're battery port terminals are probably compressed too much and not making perfect contact. Take some fine point tweezers and lift the pins inside your charge port to make a stronger connection to the charger. I do this all the time when I get units in that don't charge or have charging issues.
完成的
I didn't find any faults in the flex ribbons - but it seems that disconnecting and reassembling it solved whatever the issue is, as I've had it running smoothly for about a week now! :)
完成的
thanks, but this seems to hard for me.
ill have to go to the dude that fixed up my wii.
完成的
添加一条评论
添加你的答案
Starayo 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 91
总计 14,617
