跳转到主内容
Support for musical holiday decorations by Mr. Christmas Inc.
71 个问题 查看全部
21 Christmas carols stopped playing
Mr Christmas Holiday Merry-Go-Round
Merry-Go-Round turns, horses go up and down, light turn on but there is no sound. 21 carols are supposed to play. I have the volume turned up on high. Received from a friend. Any help out there??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Try to unscrew the roof, if it doesn't feel like the screw is raising up - stop turning as the shaft it is screwed to is also turning and this will twist the roof lights power wire inside the central shaft and rip the connection off the land on the circuit board below. This will also stop the motor supply. If you gently insert a wedge between the outer rim of the roof (push in that side's retaining tab), you can insert a pair of long nose pliers in and grip the central shaft, then you unscrew the top screw and remove the roof. Now you can look for broken wires.
这个答案有帮助吗?
得分 3
3条评论:
No broken wires??
完成的
I meant, there were no broken wires...anything else to look for?
完成的
Use a multimeter to test if you are getting any power to the speakers. Continue to test for continuity down to the output source.
完成的
添加一条评论
添加你的答案
K Marschel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 2,161
