跳转到主内容
Install SSD HD in PowerBook G4 1.5?
PowerBook G4 1.5 12" has a Fujitsu MHT2080AH 75GB HD that is failing.
Can an SSD HD be installed in the Powerbook?
If so, what specs do I need to be aware of?
Will a KingSpec T-60 SATA III 3.0 HD work?
Does it need any kind of adapter? or spacer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
No. Your machine uses an Ultra ATA/100. Even trying to find a new one of these will be very difficult (I've looked and have not found one yet, only used.)
update - here's a new one: http://www.newegg.com/Product/Product.as...
http://www.everymac.com/systems/apple/po...
这个答案有帮助吗?
得分 3
2条评论:
Does it matter if replacement HD is more than the original 80GB?
Will ATA/33, ATA/66, ATA/100, and ATA/133 work with Ultra ATA connection?
If drive is only listed as PATA/IDE, is there a way to tell if it is Ultra or other faster ATA speed?
(ATA/33, ATA/66, ATA/100, and ATA/133)
完成的
No, but I would stay under 2TB. The last limitation I remember was on G4s and as 120GB.
完成的
添加一条评论
Actually, if you are willing to build your own IDE drive you can do so as follows:
# Buy an mSata of the size you need. mSata’s are miniature SSD Sata drives https://www.amazon.com/gp/product/B07GZF...
  1. Buy and IDE to mSata converter in a case form https://www.amazon.com/gp/product/B01GRM...
  2. Put the two together and you have a SSD IDE drive
  3. Find instructions for installing an IDE in the 12” power book and away you go.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dstx 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 16
总计 1,281
