跳转到主内容
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
Controller won't connect in safe mode
Changed hard drives in the PS4 from the 500gb to a 2tb drive, have to boot to safe mode to install the " PS4UPDATE.PUP " from my flash drive and it won't accept any controllers when I connect them...
I switched the drives back and the controller worked fine when running the console but when I booted safe mode on the 500gb drive it still wouldn't accept my controller, it charges from the console but won't connect, the light just flashes white when I press the PS button, could this be faulty hard ware in the console? (Ive tried every micro usb cables on multiple different controllers, with an unpaired controller it wouldn't even attempt to sync, the controller flashed blue till it stopped looking for a console)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
Have you found the answer yet?
完成的
My ps5 is doing the same currently..
Madden 23 crashed but all other games are working fine
完成的
Op here, this was years ago on the ps4 before the ps5 was a thing, sorry to hear that its happening on the ps5
as for the ps4 my buddy had a clear DS4 controller that he used to game on his PC, unclear if its Sony DS4 or an aftermarket controller, but it talked to the console while the Sony ones I had didn't work. id just keep trying controllers and cables until something works
完成的
添加一条评论
5个答案
最有帮助的答案
I experienced this as well. It finally required an actual PS4 micro-usb cable purchased at Target for $10. All the other cables I had did nothing. May just be the type of cable…I went with the “official” Playstation usb cable. Smooth sailing from there.
这个答案有帮助吗?
得分 5
1条评论:
That’s exactly what fixed it for me, too. Went through so many USB cables until the original one finally fixed the problem.
完成的
添加一条评论
I had this same issue and was in total panic. I came across this post and luckily Jeremy had left an answer that was correct. I was at that desperate point that I’d try anything, i tried 25 different usb cables and nothing would work. I went and bought the genuine play station cable and sure as heck it worked.
这个答案有帮助吗?
得分 2
1条评论:
wow thanks a lot it was simple as changing the cord lol
完成的
添加一条评论
That's kind of a strange one. Here's what I would do...you don't actually have to boot it to safe mode to install the software. Just put the replacement hard drive in then start it up. It will prompt you to put the USB drive in, then you can install from there. See if that works.
It's possible that it's faulty software on the console but I'm not sure I've ever seen anything quite like that.
Hope this helps.
这个答案有帮助吗?
得分 1
3条评论:
Thanks for the response, but It just boots safe mode and says the PS4 can't start when I try to just turn it on, it then prompts for me to hit the ps button again with the controller plugged in, and still remains unresponsive
完成的
That's strange...when you put a new hard drive in it should ask you to insert a USB drive with the system software on it. I haven't seen one before that doesn't do that. I'm guessing it must be some sort of software issue but it's hard to know for sure without begin able to test it myself.
完成的
I'm having that exact same issue... it seems like it's becoming a more common issue. I have an original PS4 controller and the newer PS4 controller (and I've tried 5 different cables). I wonder why I can't install and load the system software.
完成的
添加一条评论
Lot of charging cables are only output cables and does not provide input back to console when you press ps button. You need to buy a data cable which takes both input and output so that when you press PS button it register input and send it back to console. Hope this helps
这个答案有帮助吗?
得分 1
1条评论:
Do you have a recommendation on what cable to get? no one ever says.
完成的
添加一条评论
My ps4 says it can pick up the updated file on my external hard drive and I've tried everything do I have to send it back to the manufacturers to see if they can help with the problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rowanwelyk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 53
总计 35,185
