跳转到主内容
初代Xbox是微软推出的第一款广受欢迎的游戏主机。它的外形设计非常易于辨认:黑色外壳,XBOX字样醒目的标在机身上盖和正面。使用常见的工具即可进行方便的维修。
Why won't my console turn on?
I had bought a preowned original xbox on Lukiegames and the system had worked fine for awhile but today it just suddenly refuses to turn on when I press either the tray button or power button. What is wrong with it and what do I have to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi Sacatuki! Does the Xbox display any sort of indicator, such as a sequence of flashing leds on the power and eject button, or an error code on screen?
Try powering on the Xbox with a different power cable, on a different outlet in your home. This will rule out a faulty power cable and/or faulty power outlet. The Original Xbox uses a generic IEC cable - you most likely will have another device that uses the same cable, and if not they only cost around $4. If it still doesn't work after that, most likely your PSU has gone bad and needs to be replaced.
这个答案有帮助吗?
得分 0
1条评论:
Ur idea is garbage, is not cable is xbox inside power supply.
完成的
添加一条评论
添加你的答案
Sacatuki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,456
