跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
How to Re-attach cable plug 1
I've replaced the screen on my iphone 3G. I've put it all back together working the directions backwards, but I can't get the last cable (labeled "1") reattached.
Can I please get some advice regarding lining this plug up so I can get it back in place?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
if you look from the side you will be able to line up the 2 connecting parts, you will feel it click into place. it shouldn't need too much pressure. It may be that you have ordered the part for a 3gs instead which will not fit the connector even though it will fit the display assembly. measure the connectors to see if they are the same size (3gs is smaller)-i'm not 100% sure if they have the same number of pins but you could also try counting to see.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,534
