跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Home button only replacement?
So, a few months ago my iPad's front screen was shattered, and also came off. I was very annoyed, and since I was in an agitated state, I peeled the middle section off, leaving glass on the inner edge of the screen. My father and I recently sat down with an iFixit replacement kit and repaired the screen. However, I could not recall where the previous home button was, but I am just going to use guided access until then. I wondering what needed replacing, where I'd get the part(s), and if I need to buy adhesive and open the screen again. (I currently have a piece of foam taped over the empty spot, just to keep it covered.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes. You'll have to apply new adhesive, if you take the new display off. Yeah, I would put the home button on, and then center the home button cable and ribbon over the hole on the new glass digitizer
Here's a guide, just in case. You shouldn't need to buy a new one, just play with how to install the old one
iPad Air WIFI版 前面板替换
这个答案有帮助吗?
得分 3
8条评论:
Ok, so do I just need to buy the home button from the parts store? Do I also need a bracket?
完成的
You will need the Home Button, bracket and cable if you dont have them. I would also recommend replacing the adhesive after removal. Also, be very careful as the screen can very easily crack when you're removing it. Time and patience is your friend here.
完成的
Oh, I'm sorry. I was confused. I didn't realize you lost the home button. Yes, you will need to buy a new home button flex cable, and a bracket. Holger Keuster is right on both accounts. Be careful, when removing the new glass. It can be broken quite easily
完成的
Just gonna finalize some things before I go to ordering, I am sure that nothing has happened to the cable for the home button, just that the button itself came up with the screen and I misplaced it. I need a flex cable, bracket, and they just go under the screen over the place where the button would go?
完成的
Yes, if you've lost the parts, from the old display, then you need to buy the new ones, and put them where the old ones were
完成的
显示更多的3条评论
添加一条评论
添加你的答案
williambivan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 784
