My laptop shutdown in every 30 to 40 minutes
my laptop shutdown in every 30 to 40 minutes and when i try to start again blue screen apear and system restart after trying 3 or 5 times its start
@valvi31, nitin , Could be overheating. Use the link below, a guide to dismantle your laptop so you can clean your computer inside. The fans and board may have accumulated a lot of dust, not allowing heat to dissipate properly causing it to over heat and shut down, the 3rd and 4th link will show how to clean. Good luck.
https://www.youtube.com/watch?v=c8HU06L4...
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 296
1条评论
It could be a thermal issue with the CPU, the laptop will shut down if it detects overheat problems. It also could indicate that the thermal detection has gotten too sensitive which would indicate a bad mother board.
由 DrGlowire 完成的
