跳转到主内容
Oppo 手机维修指南。
390 个问题 查看全部
Why is that oppo f1s is rebooting again and again after 2nd rooting?
Hello, my oppo f1s starts to reboot constantly after the second time i root it, my phone vibrates and restarts after the oppo logo is shown, it wont let me charge nor access my phone's recovery mode. it only stops rebooting when the battery is fully drained or if its rebooting for too long. Please tell me how to fix this by my own. i dont wanna go to service centre, i begging you all. I dont know if the root is the problem or just the phone itself, pls pls pls tell me, I love that phone so much. :( :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论:
Hai my oppo f1s mobile is a water damage and restart problem my solb
完成的
添加一条评论
8个答案
This is not the right place to ask root questions, as this is not related to fixing a device. Rooting is something that modifies the phone beyond its original intended design. It would be better to ask someone on xda-developers.com
这个答案有帮助吗?
得分 0
添加一条评论
u have to use advance oppo tool to flash new software . while restarting again and again you have to plug data cable ha press volume up at the same time. wait until ut finish done
这个答案有帮助吗?
得分 0
添加一条评论
You only need to do Flashing with original firmware bro.
这个答案有帮助吗?
得分 0
添加一条评论
you should try to flash new stock rom
这个答案有帮助吗?
得分 0
添加一条评论
You can repair your hp Android phone by using a flashing tool on your PC, and it can be done alone
这个答案有帮助吗?
得分 0
添加一条评论
Maybe you need to flashing a new firmware
这个答案有帮助吗?
得分 0
添加一条评论
it's very easy, just flash your ''hp '''Android''''' and finish. But that requires a lot of time. And you can search for fflashing tutorials on Google
这个答案有帮助吗?
得分 0
添加一条评论
just hard reset it. if you dont know how?
long press power button to switch it off. i mean long press until it will be off
next long press power button and volume down together until it will show the options . im tired typing bro. just search it in google. thanks to me :)
-RY Partosa
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
OPPO F1s 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 17
总计 14,109
