跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Managed to make my battery spark/short
My battery needed replacing on my iphone 6. I ordered a new one and followed a good Youtube video on how to replace it. Anyway I got to the part where I had to remove the battery and like an idiot I used a flat bladed screw driver and tried to pry the battery away from the glue (I removed one row of glue using the tabs). Anyway a small spark (almost like when you initially light a match) came from the battery then died down, then appeared again 20 seconds later. I quickly put the phone in a sealed bag, into a metal tin and now its outside.
What I want to know is, should I attempt to carry on? I don't want it to explode and potentially hurt me, or should I just bin it (properly) and buy a new phone? Thanks for the help in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Assuming your phone hasn't entirely combusted in the bin ;>)...
Follow this guide, specifically steps 20-24 on how to remove the battery safely. There are special pull tabs for safely removing a battery. Ideally, you should install new battery adhesivewhen you re-install a new battery.
iPhone 6/6s/7 Battery Adhesive Strips图片
产品
$3.99
这个答案有帮助吗?
得分 1
1条评论:
Ok, thanks. I was trying to fix my screen and I hit it down because I'm a mong and the metal from the screen hit the battery, if I'm correct, there's 3 layers on the battery and I got through the last one but the spark died down, it didn't smell nice at all and I $@$* myself when I saw the spark and I put it on the wooden table and moved everything flammable away like paper, my wallet and all that. What will happen if I plug it in now? I am very curious but if it blows up I don't want my entire phone to catch flames and have to get a new one, I'm guessing I either broke the battery or shorted it big time. Poor IPhone 6
完成的
添加一条评论
最有帮助的答案
It won't explode, it just burns and releases toxic smoke, no big deal.
这个答案有帮助吗?
得分 1
1条评论:
Yea...the match burning analogy makes me think he just popped the battery. Should be fine. Nothing I would recommend doing on purpose but it happens and I've certainly done it.
OK...I just did it last week. FINE! ARE YOU HAPPY?
完成的
添加一条评论
I've donethat on a 5. I just worked quickly to remove the battery
这个答案有帮助吗?
得分 0
添加一条评论
unless it is still plugged into the phone then you could short out / burn the connectors
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Clio 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 17
总计 5,416
