跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Where I can find the OEM Battery?
I want to know where I can fin the OEM replacement battery for my Macbook Pro 15 Retina Early 2013 A1398 . I saw one on this page but is out of stock but I still don't know if it is compatible with my model any help please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
It’s currently in stock and also carries a 1 year warranty!:
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417.图片
产品
$79.99
这个答案有帮助吗?
得分 2
2条评论:
Yes, but I said OEM. I see several complaints this isn't good as OEM.
完成的
Then you'll need to visit Apple and let them fix your system. No one offers new OEM batteries (other than Apple). You could find a used battery and that's about it.
完成的
添加一条评论
You won't find an OEM battery for any Apple computer unless it is taken from another computer. Apple does not sell parts to their products, I would assume, because they want you to pay the costly markup of them fixing it for you.
I highly suggest giving the new one (it is stated to be up to OEM Specifications, otherwise just as good, if not better, than the original Apple part) on this website a try - I did, and it's working great. The repair process was rather tedious and lengthy, but worth it if you don't want to invest $2,300 or more on a new MacBook Pro. It was also for an A1398 Model, Early 2013 15" Retina.
这个答案有帮助吗?
得分 1
添加一条评论
@elvisgonzalez I found this and says the brand is apple and the guy has a 99.2% positive feedback.
http://www.ebay.com/itm/Original-OEM-Bat...
Hope this helps!
- Jainore
这个答案有帮助吗?
得分 0
3条评论:
It says out of stock and it says doesn't fit 2013 models but thank you!
完成的
@elvisgonzalez oops, this one says in stock. Sorry about that!
http://www.ebay.com/itm/NEW-Apple-MacBoo...
完成的
I think that one would not fit my mackbook because its late 2013 :/ and mind is early 2013 but thank you for trying to help!
完成的
添加一条评论
添加你的答案
Elvis Gonzalez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 10
总计 2,614
