跳转到主内容
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Replace bottom screen if doesn't turn on but touchscreen still works?
After some water damage, my New Nintendo 3DS XL worked after a few days in a plastic bag filled with silica gel.
Two weeks later, suddenly the bottom screen won't turn on for some weird reason but the touchscreen still works fine so I can play some games if it only utilizes the top screen. I can also turn it off because the touchscreen still works. What's the best fix for this issue? Do I need to replace the bottom screen even if the touchscreen works?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The first thing I would check are the connectors where the bottom screen plugs in. These are one of the most common places to get corrosion from water damage. You'll likely notice other places on the motherboard that need to be cleaned as well.
If the screen still doesn't work after all of the cleaning then you may need a new screen, but just be sure that the connector is in good shape first. It's best to use a microscope or something to really get close and see how each pin of the connector looks.
这个答案有帮助吗?
得分 1
1条评论:
I system transfered my account to another 3DS and then the bottom screen suddenly started working again. No idea why....but just in case I will still open it up and make sure there's no corrosion. Thanks!
完成的
添加一条评论
添加你的答案
seesaw 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 332
