跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
The screen glass is cracked, works fine.
The screen is cracked really bad. It works fine no color disfunctions and no sensor disfunctions. I just want to know where in the Salt Lake Valley of Utah can I go to get it fixed for a good price. It's just the screen that's cracked nothing else.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Fix it yourself. Here's how:
三星盖乐世S5的显示屏的更换
Here's the white part:
Galaxy S5 Screen
Here's the black part(out of stock): Galaxy S5 Screen
Galaxy S5 Screen图片
产品
Galaxy S5 Screen
$79.99
这个答案有帮助吗?
得分 2
6条评论:
You can do a glass only repair for a sixteenth of that price tag...
完成的
Yeah if there is someone that does glass only on AT its recommended to try them first before going for LCD replacement.
完成的
@gigabit87898
if that is the case where can I go to do that I don't want to pay for a LCD replacement just the glass
完成的
@cripton look at iMedics answer
完成的
@gigabit87898 that's in American Fork to far from me
完成的
显示更多的1条评论
添加一条评论
Apparently these guys are in business
https://www.cellairis.com/utah-samsung-g...
这个答案有帮助吗?
得分 1
添加一条评论
If the one there is anything like the one here (mall kisok), I would not have them try a glass only repair. This is a repair that takes skill and equipment to do right. Look for a well rated, established, locally own repair shop. Make sure they cover the screen in case it is damaged during the repair.
这个答案有帮助吗?
得分 0
1条评论:
Surprisingly nobody corrected the post text title but I've fixed it now.
完成的
添加一条评论
i want to next step where i put glue in lcd
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cameron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 957
