跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
What is (unknown error 56) iPhone 6
I am getting unknown error 56 on an iPhone 6. I have used three different computers. I changed out the screen on this phone but I did retain the same home button. The phone was working perfectly fine up until trying to upgrade to 10.2. Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
i also have the same issue error 56 when try to upgrade to ipsw 10.2 and now 10.2.1 is out still same.
完成的
添加一条评论
6个答案
已选择的解决方案
According to the iPhone Wiki:
''Error 56
Most likely a dead/glitched Touch ID sensor. If seen on iPad's, try restoring the latest firmware in DFU mode. If error still occurs, bring your device to Apple. On iPhones, take out the SIM card and try restoring in DFU mode. If still occurring, bring your device to apple.''
这个答案有帮助吗?
得分 6
添加一条评论
Error 56 occurs when you try to update or restore your I phone with a hardware glitch. once occurred 90 % cases your phone needs an I C (U5301RF) change. 10 % cases it can be solved through updating itunes, turning off your anti virus, removing other USB devices from your computer or restore with another computer.
这个答案有帮助吗?
得分 2
2条评论:
I have the same issue, but the strange thing is that my iphone 7 plus was working. when i tried to upgrade to the lastest ios, i got stuck in recovery mode..... does your fix still apply????
完成的
I have an SE with same error after trying to restore phone had been dropped and has evidence of previous water damage . Does the SE suffer the same chip/hardware failure ?
完成的
添加一条评论
its due to a fault nfc ic
这个答案有帮助吗?
得分 1
5条评论:
That is wrong, NFC fault is error 53.
完成的
@pccheese it's still an answer even so we may think it is wrong. Not a good choice for a REMOVE AS NOT AN ANSWER vote. ;-)
完成的
I can confirm error 56 gone after NFC reflow or reball
完成的
I second this. U5301_RF reflow solved it.
完成的
完成的
添加一条评论
1. check the usb port
2. close all unnecessary third-party softwares
3. restore your iphone on another computer
4. update your idevice in dfu mode
5. send your idevice to apple device repair shop
这个答案有帮助吗?
得分 1
添加一条评论
ifixit actually has a video on this that i had a similar issue earlier in the week. it is explained here in their video
https://www.youtube.com/watch?v=8IEWAQiu...
Hope it helps!
这个答案有帮助吗?
得分 0
添加一条评论
Please try this steps:
1 - Install the latest version of iTunes on your computer,
2 - Make sure your iPhone is updated with the latest version of iOS,
3 - Switch on your iPhone with a SIM Card from a non compatible network,
4 - Connect your iPhone to your computer using the Original USB Cable,
5 - Launch iTunes & wait until iTunes detect your iPhone,
6 - Now disconnect your iPhone and reconnect it after 10 seconds.
Make sure to back up first your files.
这个答案有帮助吗?
得分 0
1条评论:
I have a SE with the same error code , is it likely to be the same failure . Phone had suffered screen damage and has evidence of previous water damage . Phone was being restored because it was in disable mode due the defective screen.
完成的
添加一条评论
添加你的答案
Garry Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 46,569
