My device says there is no audio output installed
My laptop is an Asus transformer T100TA Windows 8.1 32 bit operating system, x64 based processor.
So.. The other day, I was trying to install windows 10. While it was installing, the screen blacked out and it forced restarted several times. After it stopped restarting, it just cleared all of its data... Windows 10 was not installed... So it basically just factory reset itself... I don't want that happening again so I'm just going to keep Windows 8.
Now, to my problem.. The laptop can't play sounds anymore. When I hover my mouse over the speaker icon in the tool bars, it says "No audio output device is installed." I've spent so much time researching a solution but I've finally given up.
Any help is appreciated :)
Does an audio device or "unknown" device show up in device manager?
由 ETHREAL1 完成的
Also you could try making a copy of your files with file history and do a fresh install of win 10...
由 ETHREAL1 完成的
After I installed the chipset and audio drivers, the adio started working normally again. Thanks for the help, @ethreal1 :)
由 Allen Nguyen 完成的
Install drivers in c/driver , then unzip it. Open device manager from the windows, find unknown devices and after, install your driver from the location C/DRIVER.
由 Thanasis Antoniou 完成的
you may visit: https://bit.ly/2LIXkU4
由 Mark 完成的
显示更多的2条评论
