跳转到主内容
How do I clean dust from my fan and vents
I have an overheating problem and may need a new fan but I am told that I need to blow out the fan vents and may actually have to take out the fan and clean it to solve the problem rather than replace it. How do you do this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Get some compressed air from like an office store (or Walmart) in the electronics department and blow out the dust with the air if its still over heating see if there are strange sounds coming from the fans if so you probable have a bad fan bearing and if you hear nothing the fan may have died (make sure to be running something prossesor intensive such as "geek bench" or "fur mark" as many computers dont need the fans on when idling or doing non intensive tasks) and you can open it up and blow out the dust as well
这个答案有帮助吗?
得分 0
1条评论:
Also if you take the fan out Q-tips and alcohol to clean the blades
完成的
添加一条评论
添加你的答案
Rob Haines 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 682
