跳转到主内容
加入维修社区 - 创建账户
What causes the 99 tahoe to overcorrect itself while turning right
All right turns, 99 tahoe jerks to the right. I was told it was "overcorrecting" itself. I would like to know what causes this jerking, its not safe, you have no control over the jerking. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
Does it make a clicking sound as well when you turn right? It might be that the CV joint needs to be checked.
Whatever the reason for it, get it checked out by an automobile steering repair service.
完成的
A right caliper could be sticking also. Is it smoking or have a bad smell after driving the truck?
It's common that a brake line can go bad internally acting like a check valve and intermittently not let the caliper release.
Other things not mentioned that could cause this would be a worn Pitman Arm, Tie Rod Ends, or Upper and Lower Control Arms.
完成的
添加一条评论
2个答案
已选择的解决方案
@tahoemommy33 , CHRISTY, COULD BE A SAFETY HAZARD. HAVE A GOOD SHOP CHECK THE SPEED SENSOR THAT CONTROLS THE SPEED SENSITIVE STEERING COULD BE FAULTY , MY SON HAD THIS PROBLEM AND SENSOR HAD TO BE REPLACED.
SORRY CAPS LOCK BUTTON STUCK.
See link below for test and replace of power steering EVO turning speed sensor. Good luck.
https://www.youtube.com/watch?v=7dlZQFQu...
这个答案有帮助吗?
得分 2
添加一条评论
Check to make sure it's not in 4x4. If you have option, put it in Auto 4x4 or make sure it's in 2 wheel drive. I had a 2008 GMC that would do that on dry pavement if 4x4 was on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 711
