跳转到主内容
Left USB not working after liquid spill and cleaning
Early 2014 13" Air: left USB stopped working after major liquid spill and subsequent tear down and cleaning. After the "accident" I inverted the computer and dried with a large fan for 48 hours. Then tore down the machine, removed the I/O card and gave it thorough cleaning with Isopropyl. Luckily after reassembly and for 1 more day everything working fine. But today, day 3 following cleaning, left USB stopped working. I'm ready to replace the I/O board and have one ordered. But wanted to see if the community has any other suggestions before I proceed with the replacement.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try an I/O board, check the I/O cable for burnt pins and also the I/O port on the logic board.
Check the bottom of the board for liquid too, since there are some components which are for the external USB port on the I/O board.
这个答案有帮助吗?
得分 2
4条评论:
I did check and clean bottom of the board. I will check the cable. But would a bad cable only effect the USB? The MagSafe power input and the headphone jack are also on the board and working fine? Thanks
完成的
If there was liquid on the bottom of the board, check to see if any components were affected or burnt in the area, this is likely causing your issue. Yes, the cable can be burnt on one of the pins for transmitting USB data (the pins for speaker, headphone jack, etc are separate).
Don't spend too much time until you try a test I/O board first.
完成的
Actually. A bad I/O board cable can also affect the audio functionality of the MacBook including headphone jack.
The I/O board has an cirrus audio chip on it which controls the audio and headphone jack audio.
The reason I know this is because I just had a MacBook Pro 13" come in this week with liquid inside the connector and ribbon cable connector side as well which stopped internal speaker and headphone speaker audio from working at all.
完成的
Yes that's what I mean, the speaker, headphone jack, etc are on different pins of the I/O cable. It is possible for just the USB not to work if this pin was burnt, and the ones for audio are not.
Had one like this before (wasn't charging battery, but turned on fine) which was caused by a bad I/O port, see Dim Green Light, Turns On Fine, Not Charging Battery
完成的
添加一条评论
I have a 2014 Lexus is250 and a liquid just fell in my USB ports and now it smells burnt and I even noticed that it was a bit burnt, it doesn’t charge my phone and now I am just scared and do not know what to do because I do not know if it will ever work :( please help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jay Quilty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 7,120
