跳转到主内容
Apple 于2015年10月14日发布第二代支援多点触控的无线鼠标。型号为A1657。请在本页寻找该产品的维修指南和疑难解答。
20 个问题 查看全部
The top casing feels "loose", any way to fix it?
Ever since i got my Magic Mouse 2, the top plastic casing has felt kinda "loose" and a bit wobbly, so every time i loosely click it or run my fingers over it, it does not feel good.
Is there any way to fix this, apart from buying a completely new one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
@erikeia, Erik Eia , Ifixit rated trying to repair this mouse a 2 out of 10. From the link #1 below you can see the tear down, to see if you want to attempt to open the mouse and see if you can repair loose /wobbly case. If the top is just a little loose from the bottom you could try a little fast setting gel glue at the seam. Link #2 is just an example of glue that may be used. make model # and your complete question, so we at Fixya can answer your question effectively.
Magic Mouse 2
http://www.gorillatough.com/gorilla-supe...
这个答案有帮助吗?
得分 6
1条评论:
I´ll see, thx
完成的
添加一条评论
添加你的答案
Erik Eia 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 47
总计 4,970
