跳转到主内容
加入维修社区 - 创建账户
TH(涡轮增压自动)700R4 变速箱于 1982 年后开始用于 GMC 和雪佛兰的汽车与卡车。
Won't shift into gear.
I installed a rebuilt transmission from a reputable company along with a used (freshen up with new seals) transfercase and new standard torque converter. I put a quart in the torque converter before install, 6qts in the transmission before startup. I ran the engine till warmup checking the fluid in the process. I moved the shifter through all the gears and back. When i went to put it in park sounded like the transmission was rotating because of the grind on the parking pin. My question is the truck does not shift into gear either forward or reverse could it be the transmission or transfer case? Do i need to readjust the TV cable? I double and triple check all connections.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I having the same exact issue but I got it to move when in 4 low is this transmission or transfer case
完成的
添加一条评论
1个答案
最有帮助的答案
@dgrenon, Make sure your transfer case is not in neutral. The reason you get the grind when you try to put it into park. If the transfer case is in gear, then there is something wrong with that; not the transmission. Without the wheels engaged via the transfer case, there is nothing to stop the rotation inside the transmission so that you can put it into park.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 5,956
