跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
What is this component and will it work without it?
Hello,
I'm trying to fix my logic board to my iPod touch 5. While removing the emi shields, I broke off 2 components and an entire IC. What do they do and will they function without it?
The IC is right below the a5 and the 2 components are near the screw hole in the bottom right.
Update:
Maybe it is the Tristar IC?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@gigabit87898 schematics and boardview files are not available for any iPod touch. The only way to determine what the components is would be by getting a replacement board and then trying to measure the part or by harvesting it. That is the reason why you do not see any board level repair on those widely advertised.
完成的
添加一条评论
1个答案
已选择的解决方案
Step 21 mentions the IC: iPod Touch 5th Generation Teardown
If you cannot get a schematic/boardview for this model, would recommend buying a dead iPod touch 5 and switching the parts, or getting a donor board for this model. No idea what the component does, but hope this helps :)
这个答案有帮助吗?
得分 3
2条评论:
Thanks, but I think I tore the pads on the board... If it is a Tristar chip I will just back up my data really quick haha.
完成的
The Tristar IC is below the NAND. What you're missing is not the Tristar.
完成的
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 684
