跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
I think I broke everything.
I tried a repair on this laptop made by the devil. Broke multiple things on logic board. Fan, Trackpad, and one of the connectors to the wireless card. Is there anywhere I can send this so I can just tap out? I don't know if its even worth fixing at this point.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I broke the charging port off the circut bord. The wire that connects the fan to the logic board is broken. Multiple track pad wires are broken. one of the three pins that connects to the wireless card is broken.
完成的
@mayer may know someone....
完成的
添加一条评论
3个答案
已选择的解决方案
Sounds like repair may not be your forte.
Well I've only been repairing them since 1979. Yours may not have been made by the devil but it sounds like it certainly been worked on by something akin to one. As a pastor as well as a Mac repairman I can perform an exorcism on it, attempt to purge it from the curses that almost certainly have been heaped upon it. For those services, I do not charge. But for replacing the logic board, I do charge, Apple most likely will not touch it except for a price close to the cost of the whole thing. I usually do not solicit business on this site and this is really not a solicitation but an offer for a solution. Click on my icon and email me. Tell me the truth about why you were even in it in the first place and what else was damaged. I'm 97% sure I can get it working for you at a price better than you will find elsewhere. It sounds like you will need a real expert to resurrect it.
这个答案有帮助吗?
得分 2
1条评论:
You make me wish I had a repair business.
完成的
添加一条评论
If you want the old motherboard repaired, send it to @jessabethany at iPad rehab. It would probibly be easier to replace it, but more expensive.
这个答案有帮助吗?
得分 0
1条评论:
She really doesn't do Macs. She does phones and pads.
完成的
添加一条评论
You can always ship it to Apple! Schedule an appointment at your local Genius Bar and see what your options are.
这个答案有帮助吗?
得分 -1
1条评论:
@entendu they won't fix it, they will tell you to get a new logic board.
完成的
添加一条评论
添加你的答案
Brad Morgan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 159
