跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
The age old liquid spuill on keyboard question
Hi
I know this is a common question but I have spilt ginger beer ion my laptop keyboard , I cleaned up and turned off as per the advice on this site , I then a day later started using it again and it was fine although a bit sticky , used a cleaner to clean the keys which worked then a day later a few keys died. I then had to go away so packed up the computer (powered off) into my bag and went away I opened u the laptop at work only to discover that it would not power up , it has been lying with everything removed for about a week in a bay of rice to absorb any excess moisture but still not joy. So could I get away with just buying a new keyboard for $249 of do I need a new logic board as well? And if I order both parts (am in the UK) and I don't open the logicboard can it be returned?
Thanks
Richard
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would check the liquid indicator sticker located in your MacBook to see what got wet, Here's where they are located: http://www.appleinsider.com/articles/08/...
also check here:
http://www.myservice.com/blog/tag/MacBoo...
http://www.roughlydrafted.com/2008/10/15...
Page 19 here: http://www.scribd.com/doc/16070357/Apple...
这个答案有帮助吗?
得分 2
1条评论:
good answer +
完成的
添加一条评论
添加你的答案
richardvereker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 1,816
