跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
426 个问题 查看全部
2000 honda accord tail and dash lights not working.
#10 fuse is good on my 2000 honda accord. My son, while tinkering with front marker light, shocked himself. Now no dash lights, parking lights or tail lights. What is fastest solution to find problem.
2000 Honda accord
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
On my 20001 Honda accord my tail lights work but instrument lights don't
完成的
添加一条评论
2个答案
已选择的解决方案
Kat, Recheck for blown 7.5 or10 amp fuse I think, in the passenger side door jam fuse box, may be marked tail/dash #10. Other fuses to check driver side dash fuse box: Fuse # 9 (7.5A), #10 (7.5A) , passenger side dash fuse box: Fuse # 10 (10A) ,under hood fuse/relay box: Fuse # 47 (20A), #49 (15A)
Good luck.
这个答案有帮助吗?
得分 12
9条评论:
Thank you so much. I had no idea there was a second fuse box on passenger side. Praise the Lord.
完成的
Kat, Happy I was able to assist and thanks for replying back, so few do and it is nice to know when answer helps. Have a good day.
完成的
First of all, forgive me, as I'm learning what I'm doing as I go. I have an 01 Accord, and my instrument cluster has no lights, and I have no back lights. However, my break lights, headlights, and blinkers work. I've replaced the multi switch, but the issue persist. The #9 fuse on the passenger side is labeled, "instrument panel/back up lights". Manual says 7.5 amp, but it has a 20 amp fuse in it. The fuse is good. I put a 7.5 amp fuse in it, but nothing changed. Any help/advice would be greatly appreciated.
完成的
Hello Jason did you find out want the problem was? Having the same issue
完成的
Hi, i changed fuse #10 on passenger side is labeled "small lights", an then , the lights on panel works again, but aproximately 15 min, the fuse breaks. I this moment I looking for the wiriing diagram, but i dont get good results. My car is honda accord 2000 standar
完成的
显示更多的4条评论
添加一条评论
Thank you!!! You save me a big headache.
这个答案有帮助吗?
得分 1
4条评论:
Does that go for 98 Honda Accord two I got no dashboard lights or interior or parking
完成的
Never mind yeah there’s one on the passenger side of a 98 to
完成的
L pfaff thank u so much!!!
完成的
thank you my problem was fixed with the side panel fuse!!
i had taken it to a mechanic and was told it was the wiring in on off lights switch in the steering wheel.
thank you so much no more driving at night with hazard light on off i got caught in the dark
完成的
添加一条评论
添加你的答案
Kat 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 84
总计 42,322
