跳转到主内容
加入维修社区 - 创建账户
Xbox 360 是微软于2005年11月22日推出的第二代电视游戏主机。
How to replace dvd drive
What other brands of dvd deives can be used
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I found this response to your question:
"You cannot replace the disc drive in your Xbox 360.
The DVD drive will only work on the original console it was installed on. They are have a key on the firmware that has to match a key on the motherboards JTAG otherwise it wont work.
You could Spoof the drive though but you need to look that up on your own as me telling you how would be against the rules.
You can replace the laser assembly but that is if you purchased the same drive as your original console had.
Otherwise you need to find an the same drive or a laser assembly that will fit your drive. But you cannot use a new drive."
http://www.tomshardware.com/forum/116656...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frans 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 58
