跳转到主内容
GoPro Hero5 Black是GoPro于2016年10月发布的高清防水运动相机。具有4k分辨率录制和语音控制,触摸屏显示和内置WiFi功能。
85 个问题 查看全部
LCD not lighting up
I accidentally inserted the sd card into the small gap between the sd card slot and the battery. Now the LCD doesn't light up but is still touch sensitive. Besides that, the camera is still fully functional. Can I fix this myself or will I have to send it to gopro? Also does warranty cover this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hello Bob John,
This could be caused by you accidentally removing the LCD connector when you inserted the SD Card. Can you can open the Gopro and look to see if you accidentally disconnected a cable. When you open also look to see if you did some damage to the Logic Board and let me know what you find out.
I wish you luck and I can do more help if you have any questions please comment on this and Ill get back to you.
Thanks,
Keegan Bourque
完成的
添加一条评论
1个答案
Contact costomer support. They'll help you fix it or fix it for you. The warranty will be void if you open it up though, so I don't recommend that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bob john 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 259
