跳转到主内容
American Edition released in 2013, identified by model number X502CA
11 个问题 查看全部
Stuck in bios mode after updating to windows 10
So yesterday I was updating my computer and it was downloading windows 10. It got all the way to 100% before it froze for about 2 hers. When I restarted it, it immediately went to Aptio Setup Utility. I have tried everything mentioned. Taking it apart, turning it on and off again, enabling and disabling you name it. Before updating my computer there was literally nothing wrong. Now it seems Im &&^&@@. Has anyone else had this issue when updating?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Go on another working computer and make a Windows 10 install/recovery media by going to this link and following the instructions
https://www.microsoft.com/en-us/software...
Insert the disk into the computer and boot up. In the bios, go to the boot tab and select the usb drive under boot override.
You should be booted into the windows recovery disk. Do not remove the disk. Go to repair my computer and select automatic recovery. If that does not work, then you will need to perform a fresh install.
这个答案有帮助吗?
得分 0
1条评论:
Yup .... that's the only real way
完成的
添加一条评论
添加你的答案
Frank Rojas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 988
