跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5S - Apple Logo, & Black Screen Shows Up Stuck
My dad has this iPhone 5S that had been water damaged for a long time. I cleaned all the parts with 90% isopropyl alcohol. When I boot up the phone, the dead battery logo shows up, then the apple logo and then a black screen until I unplug it, it stops working. What's the issue? Also I tried unplugging the battery port from the motherboard then charging it and booting it, but it still doesn't work. I looked up tutorials and found how I should replace the battery, but I'm not sure that's the issue since it doesn't boot up at all when I charge the phone without the battery plugged in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
The iPhone 5S will not boot up without a battery; it just shows the Apple logo and then restarts again. You need to have a working battery, even if it's not in perfect condition.
Looking at your question...
What do you mean by that? Did you take out the battery and charge it independently of the device? That sentence is not clear enough for us to understand.
@oldturkey03 is correct. You need to isolate some variables and work with known-goods, especially with water damaged devices. The fact that iTunes detects your phone tells me the charge port assembly is most likely okay. The battery is an obvious element to replace but because you have very old water damage to the device, I would suspect a logic board issue, most likely the charge circuit.
Did you remove the shields when you cleaned your logic board? If not, that's where 80% of the electronics resides and most likely where the problem is. At that point, you need to de-solder the shields.
So I would try the battery first. Then if that doesn't solve your problem, you should consider a shop that can do micro-soldering repairs to do the diagnostic for you.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
@iapple change the battery first. Even if it does not have the desired result, at least it will provide a known-well starting point for further troubleshooting. Water damaged devices are the toughest to diagnose and repair since virtually any part may have failed.
这个答案有帮助吗?
得分 1
6条评论:
@oldturkey03 shouldn't it still boot up even if I plug in the charger without the battery plugged in the logic board?
完成的
@iapple not necessarily. I've had a few that did not. I am sure you are suspecting yourself that the battery is toast anyway; go ahead replace it.
完成的
@oldturkey03 Is there a proper way to diagnose this? I don't want to waste money on a battery and not be sure if it'll even work or not...
完成的
@iapple you will have to use the schematic and board layout and check the power rails for shortcircuits etc. Again, at this point you do not know which point is good. A new battery will give you that starting point.
完成的
@oldturkey03 I've tried to put the device in DFU mode, with the battery plugged in, itunes detected the device. When I clicked restore, I got an error 2002 and error 2006. Does this help confirm the issue or would it still be considered unknown?
完成的
显示更多的1条评论
添加一条评论
My phone is not start only apple logo start but not start phon only apple logo start on /off?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iApple 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 2,821
