跳转到主内容
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 个问题 查看全部
Starter and more 92 Sierra 1500 rwd
Need to replace starter. How easy outs that? Is it necessary for a mechanic or easy enough for a dyi job? Also when i tried to crank it, behind the dash under the hood on the passenger side it smoked a little. What could that be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
first off the starter is an easy fix 2 to 3 bolts usually hold it on and some wires on the solenoid . The smoke was probably from the wiring on the starter overheating . So with this in mind before replacing the starter check the connections at the starter. there may be a bad contact causing the problem or just the starter solenoid on the starter . Try by passing the solenoid t o see if that's the problem. Hope this helps
https://www.youtube.com/watch?v=fbOBExao...
这个答案有帮助吗?
得分 1
添加一条评论
Mahara, 1992 Sierra 1500 starter replacement not a bad job to do a little tight. Link below will show what is involved in replacing starter. As far as the smoke you saw, may have been starting circuit wires that overheated from bad starter, remove wrapping on wire bundle and check wires for burnt/damage and make necessary repairs.Good luck.
https://www.youtube.com/watch?v=XvfI9XsI...
这个答案有帮助吗?
得分 1
1条评论:
I have seen this new starter replacement kit want to know more about it.
完成的
添加一条评论
添加你的答案
Mahara Taylor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 631
