跳转到主内容
The VTech InnoTab 2s is a kids education tablet that teaches them to read, write, and think logically and creatively.
Why is my device not turning on?
I'm pressing the power button on my tablet but it's not turning on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
If your device is not plugged in using the VTech® recommended Power Adapter, then your batteries could need replacement. Check to see if your AA batteries aren't depleted. Try plugging in your device using the Power Adapter. One of these suggestions should help you with this issue.
If you plugged in your Power Adapter and you're still not able to turn on your tablet, then you might have an issue with that Power Adapter or with the power connecting port on the device. Consider replacing the power adapter or replacing the power connection port. If you replaced the batteries with working batteries and your device is still not powering up, then you might want to consider replacing the circuit board.
这个答案有帮助吗?
得分 3
添加一条评论
Ensure that there are new batteries installed into the device. If using the power supply make sure that the power supply is plugged into a working wall socket. If it is plugged in properly you may need to replace the power supply socket, a guide can be found here for it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Esthevan Romeiro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,697
