跳转到主内容
Samsung Gear S,设备型号SM-R750,是一台可以和你Android智能手机连接的智能手表。Samsung Gear S发布于2014年10月
42 个问题 查看全部
Can you replace the case.
Hi,
looking at the pictures, can you replace the case on my gear s. It has broken such that I cannot attach the charger.
Many thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
I also have this problem
完成的
Just replaced it with a body from aliexpress! Don't know about the seal between body and screen.
完成的
添加一条评论
3个答案
已选择的解决方案
Here's one source for parts:
http://rounded.com/galaxy-gear-s-sm-r750...
这个答案有帮助吗?
得分 5
2条评论:
I have been using the tape method and a rubber band method too. Now my battery doesn't hold a charge all day. I'm good to get six hours from it.
I'm thinking about another watch. Any suggestions on brand.
完成的
Buddy that kind of depends on what you use the watch for. One size does not fit all.
完成的
添加一条评论
I've had my GearS since 2014, and I love it. Not only does it do everything it is meant to do, it does it well, and it is still a great conversation starter!
But a half a year ago, the little plastic band on the back of the device that clips on to the charger, broke off. I would guess that's what happened to yours too.
I did not find a way to repair it, but I did find a simple fix tha actually works:
First, attach your charger to the mains, so you know it has power.
then, gently slide the device in place over the charger and listen for the beep that tells you that they are connected. Hold the two device together with one hand (index finger and thumb above and below the screen, third finger at the back of the charger.
Finally, with your free hand, pull approximately thre inches of Scotch tape from a table dispenser, (I prefer the 3M magic invisible) and simply stick the two pieces together, passing the tape from the back of the charger, across he face of the clock to the opposite side of the charger.
The whole operation takes about five seconds, and works every time! When charging is completed, the tape comes off easily and leaves no trace.
Like I said; it is no repair, but it gets the job done!
Best regards
Gotmar Rustad
Norway
这个答案有帮助吗?
得分 1
添加一条评论
I use a clamp……………..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rob bannister 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 1,659
