跳转到主内容
发布于2013年11月22日的微软第三代Xbox游戏主机。
Why won't my Xbox One turn on?
My Xbox One hasn't been able to turn on for a while. I've tried every suggestion on www.xbox.com but it still won't work. When I turn it on,my controller will start blinking and it won't show it on the screen. If anyone can help,that would be great.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
8条评论
Does the console itself come on (Does the light on the front come on and stay on)?
完成的
No,it hasn't turned on like that since I bought it.
完成的
Is it still under warranty?
完成的
What color is the light on the power brick? And does it change when you try to power on the xbox? (Don't use controller) also does it make the "ding" sound when you try to power it on?
完成的
I'll try that out today. And it isn't the power brick.
完成的
显示更多的3条评论
添加一条评论
3个答案
已选择的解决方案
If you just got the Xbox from someplace like bestbuy it will be under warranty for about 1 year after purchase so just get the free replacement if you got it from a friend check if it's still under warranty at Xbox.com if it's not and it's not the power supply you can have Microsoft repair the console if the tampering sticker is not damaged that would be your best bet, if you would like to have me help troubleshoot I am here to help
这个答案有帮助吗?
得分 2
添加一条评论
Well,here's the answer: A Fallout 4 Mod (Blacksmith Anywhere) has fried my motherboard and it circuits from the system. Only 2 options: Check for warranty and send it to Microsoft to fix it or just buy a new one.
这个答案有帮助吗?
得分 1
添加一条评论
from my experience i could say that is changing the power supply is the solution because it is more familiar that it is power supply issue in xbox.
i wish this helped you :)
这个答案有帮助吗?
得分 0
7条评论:
does my answer helped or there is other answer?
完成的
Other answer,but this is still helpful for other people with this problem.
完成的
could you please let me know that answer plz..
完成的
That may be the answer but we still have not determined the problem, I.E. power supply or console
完成的
I'm waiting to know the answer ...
plz make it done Danny .
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Danny Camacho 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 6,289
