跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
iPhone 5c won't charge past 3%
My iPhone 5c won't charge and the charger is brand new but after I plugged it into my moms Dodge Journey USB port my phone stoped charging , now it dies and turns back on but doesn't charge past 3% and the lighting bolt doesn't pop up , does it need a new battery ? Help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The iPhone charging subsystem can be damaged by non-MFi (Made for iDevice) certified chargers. Based on the sequence of events you describe, this is what happened to your phone. Cheap dollar-store charging bricks also can cause this.
While it is possible that your battery is defective, I believe that the Tristar(U2) IC on your device was damaged by the USB port. This is not a DIY repair unless you have experience in micro-soldering.
If you have access to a known-good battery, you can always replace it. If a known-good battery does not charge, then it is a U2 problem.
iPhone 5c 电池更换
The 5C also suffers from micro-fractures on the logic board so this could also be the root problem on your device. A qualified repair shop that does micro-soldering should be able to troubleshoot your device properly if you don't want to do it yourself.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shadiamond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,900
