跳转到主内容
The HP Pavilion G6-2249wm is a 15.6-inch laptop in the G6 series.
Computer black screen caps lock key flashes and comp beeps
When I startup my computer it beeps then the caps lock key flashes while the screen stays dark. I have tried dissasembling and assembling again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Hi, Here is a link that describes the problem(s) depending on how many beeps and which lights are flashing. Use it to determine where the problem is and then get back here if you need more assistance.
http://h20564.www2.hp.com/hpsc/doc/publi...
完成的
I know about that page already but I'm a tech dunce so I don't know what they're talking about, as well the eg they give dont apply to my current problem.
完成的
Hi, Count the beeps, see if it is a sequence e.g 2 beeps pause 2 beeps pause etc, what is the beep code as you hear it, plus is it only the caps light blinking?
完成的
添加一条评论
1个答案
Finally fixed it don't know how all O did was dissasemble every piece and reaasemble it, except I still have a loud overheating fan even after cleaning it.
这个答案有帮助吗?
得分 0
4条评论:
Check what you did again to make sure everything is OK
完成的
I recommend changing the thermal paste under the heatsink for CPU.
完成的
@pyrojanus while you replace the thermal paste I'd go ahead and replace the fan as well. That way you do not have to continue to tear your computer apart....
完成的
Where can I buy thermal paste? Best Buy, or any hardware/computer store?
完成的
添加一条评论
添加你的答案
Janus Piro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,592
