跳转到主内容
加入维修社区 - 创建账户
iBook G4 won't turn on
I have inherited a non-working iBook G4. I would like to fix it and get it working again. The person it used to belong to said she was watching a movie on the iBook, then it suddenly shut off. Now she can't get it to turn back on, even with it plugged in.
The laptop was taken apart (completely) in order to extract the DVD that got stuck in the laptop when it died. I have re-attached the DC-In board and re-attached the power button. That should be all I need in order to get it to turn on. I plug the charger into the DC-In port, the charger lights up, but when I press the power button, nothing happens.
I'm not sure if the DC-In board is the problem, or if it is something else. How can I go about testing the DC-In board to see if it is working or not? Or, what steps should I take to go about determining the cause of this problem? What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
First put it back together. Then you can get some real diagnostics. Lights, tones and other sounds. Use a multimeter to test your DC-IN board. Here's a guide that may help you: iBook G4 14" 933 MHz-1.33 GHz Logic Board Replacement
这个答案有帮助吗?
得分 3
3条评论:
I have re-attached the DC-In board and re-attached the power button. That should be all I need in order to get it to turn on. I plug the charger into the DC-In port, the charger lights up, but when I press the power button, nothing happens. What should I do?
完成的
Use a multimeter and test the output of the DC_IN board with the charger plugged in.
完成的
agreed +
完成的
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 2,183
