跳转到主内容
加入维修社区 - 创建账户
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
eMac won't boot either
Emac will not boot after last software update. Will not boot from hard drive or disk. Three things happen. First, I get a kernal panic and freeze after a few seconds, or the computer shuts down. or the spining indicator goes on indefinitely. On rare occasions, I get the symbol for OS not found. I have reset the PRAM and I get both bongs. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks for suggestions, but nothing worked to boot the machine. I do not know if we are facing a bad hard disk or mother board. If it was a hard disk, I assume I should have been able to boot from the install disk. So I fear it's a mother board. Until next time....Adios
完成的
添加一条评论
2个答案
已选择的解决方案
Boot from your system installation disk by inserting the disk and starting up holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk utility and repir the hard drive till it runs clear. Then try restarting.
这个答案有帮助吗?
得分 2
1条评论:
agreed +
完成的
添加一条评论
Sounds like one of the updates failed. If you still have the install disks, you can reinstall the operating system and select the option to save all of the old files in a folder called "Previous System" If you want to keep them, and have inportant info that you want to keep. Short of that, there is no way to really fix this.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
professor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,264
