跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
How do I disable the onboard RAM on an iBook?
Hi! I've got an iBook G3 that is giving me kernel panics, and I'm 99.9% sure it's due to bad onboard memory. This specific machine aside, does anyone know how to disable onboard RAM on an iBook G3/G4? I once saw a guide to cutting the paths to the RAM on the logic board, but that seems a little extreme, and I'm wondering if there's an easier and more effective method, perhaps a command line command I can enter?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi, here's a URL on how to do that--make sure you scan down to get to what you need. Good luck. Ralph
http://osxbook.com/book/bonus/ancient/wh...
这个答案有帮助吗?
得分 2
2条评论:
Actually I read the document, and while it's got good info, it doesn't discuss disabling onboard iBook RAM. Does anyone know how to do this? Thanks
完成的
Could you find the installed memory address and use the procedure listed to temporarily shut it off? Ralph
完成的
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,461
