跳转到主内容
A 10.2-Megapixel digital SLR camera by Nikon.
15 个问题 查看全部
Still turns on and works but the picture is black screen
My camera was working fine and then all of the sudden the images started all looking like squiggly vertical colored lines
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@moondog are you referring to the actual pictures you are taking or the images you see on your LCD screen? which one has squiggly lines?
Rep: 1
完成的
The LCD screen works fine. I can see earlier pictures on my card and all the menu etc. The pictures are what are squiggly now.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
If your camera can still take pictures OK even though you cannot view them in the LCD screen, but are OK when you download them to view, then most probably the LCD screen is faulty.
Here is a link to the Ifixit guide on how to replace your LCD screen.
Nikon D3000 LCD Screen Replacement
Here is a link to just one supplier of the replacement part. This is just to give you an idea of the cost of the part. Just search online for others if this doesn't suit.
https://www.aliexpress.com/popular/nikon...
Update (11/20/2016)
Hi
It seems as though the image sensor in the camera has either gone faulty or has a loose connection.
Here is a link to the Ifixit guide repair guide to get access to the sensor.
Disassembling Nikon D3000
Here is a link to just one provider of the replacement part.
http://www.ebay.com/itm/Nikon-D3000-CCD-...
Nikon D3000 LCD, rear circuit board and sensor图片
指南
难度:
困难
1 hour
Nikon D3000 LCD Screen图片
指南
难度:
简单
40 minutes
这个答案有帮助吗?
得分 2
添加一条评论
Your unit has lcd defective. You can do yourself or bring to your local repair shop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SB Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 2,131
