跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Will only boot to the folder with question mark
My first Imac will only boot to the folder with question mark. I bought a second and similar imac and changed the hard drives but this first one will still not boot with the new hard drive. However on the second Imac both hard drives will boot
What could be the problem with the first Imac?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
A folder with a question mark means the computer cannot find a start-up folder. If you are getting this, it's not booting correctly. If the computer eventually boots, go to the System Preferences and select the start-up drive you want it to boot from. If it fails to boot at all then boot from your system installation DVD and go to the second screen pull down menu to Utilities -> Disk Utility and see if it will see the hard drive. If it does try repairing it.
这个答案有帮助吗?
得分 2
添加一条评论
Cable
or connector... more serious (logic board) problem if there was an electrical spike to the first one.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Francis Obi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,922
