跳转到主内容
The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
How do you get into this thing
AAAAAARRRRGHHHH
Someone help how the heck do you get into this thing?
this has turned into a nightmare I'm replacing the dock port on this I've already busted the screen (glass just came straight off the LCD but thats a whole different story)
I have also removed the 13 screws from the frame under then screen but i cannot get all the casing off the other side to get into where the motherboard & dock port is.
I have undone the clips on the inside of the battery recess but it all is stuck down tight i don't want to force it too much this repair has already cost me big time
Someone PLEASE help & point me in the right direction
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@inthebox ,Kenny, Link to partial tear down of the S5 Neo and a 2nd link which may have more info., Good luck.
Samsung galaxy s5 neo Display Replacement
http://www.sonymobilephones.com/samsung-...
这个答案有帮助吗?
得分 3
2条评论:
Hi Thank you for that i did see that but it only goes as far as taking screen out not going in as far as getting motherboard out. Someone was kind enough to come & show me how. Its deceiving it looks like it should come away from the outer frame thats what i was looking at & couldn't figure it out it actually comes apart inside.
完成的
@inthebox ,Kenny, thanks for posting back, happy to here you had success with your device. Have a good day.
完成的
添加一条评论
添加你的答案
Kenny Leonard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 418
