跳转到主内容
The rear camera glass broke
My HTC desire 626 rear camera glass broke it should be repaired by service center or not please relay
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It is completely your decision. If you can find a service centre, it is usually your best bet, but usually rear camera glass replacements are fairly easy to carry out on most models.
这个答案有帮助吗?
得分 2
1条评论:
Here's the guide on how to do it:
HTC One M8 后盖替换
完成的
添加一条评论
I also had that phone and had to take it apart to change the battery so I realized the camera glass is actually part of the middle housing, which you can get for less than 6 bucks. All you have to do is remove the back and take the middle housing off by unscrewing the screws that hold it in place, replace with a new one then screw the screws back and snap the back back on. There are 2 diff types of screws btw, one takes a tiny Phillips head and the other is like a *shape.
https://www.parts4repair.com/middle-hous...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manish kumar maurya 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 59
